Sponsored by: CARiD
LED Main Lighting - Technical
Old Jun 21, 2011 | 06:34 AM
wdtd's Avatar
Default LED Main Lighting - Technical
Looking at LED's for DRL's, Turn, Highbeam, etc.? Have you found truly equivalent light output?
For 'white' lights, the equivalent lumen output that utilizes the original reflector and lens seems straightforward. If the LED version has only 20%, 50%, or 75% of the lumens available, likely that LED won't be good enough.
What about amber (and red in some cases)? When an incandescent bulb for the turn signal puts out 400 - 500 lumens (bulb number 7440 on a MY07), and the lens allows only the yellow/amber range through, what percentage of the light output is thrown away? If 85% of the light from the bulb (red, green, blue, violet portions of the spectrum) then an amber LED replacement of about 70 lumens would seem reasonable. But what percentage of the total white light is really blocked by the yellow/amber lens?
J1mmys
Dec 2, 2013 09:36 AM
rb4065
Apr 15, 2009 01:46 AM
dopesilverstone
Mar 1, 2009 01:36 PM
Shinji
Apr 3, 2002 08:14 AM
djvtecs2k
Oct 27, 2001 03:56 PM
