Tail light turn signals?
Old Oct 26, 2001 | 07:21 PM
djvtecs2k's Avatar
Default Tail light turn signals?
I would liek to change my tail light turn signals to red but these freakn bulbs have wierd studs on them so normal bulbs don't fit. I want all red turn signals and this is upseting me. any bodey know where i can get some rear tail light turn signal bulbs in RED.
Thanks
Big pun
Old Oct 27, 2001 | 12:37 AM
4IGS2000's Avatar
Spammer
1156 bulb my friend. If it doesnt fit its the 1156 Euro-Spec bulb. Grind off one of the stubs.
Old Oct 27, 2001 | 03:56 PM
1Y2KS2K's Avatar
djvtecs2k: I think you're talking about the wrong bulb. The turn signal light is an 1156A; it's the same as a standard 1156 bulb which has a regular bayonet type base. The "A" denotes that the glass is Amber colored. When signalling, the light shines amber through the frosted lens. The backup light is mounted directly below the turn signal light. It's a type 7440 and has a wedge base and made of clear glass. Is this the one you say has "weird studs" on the base? If so, you've picked the wrong bulb!
So......if you want to change your AMBER turn signal bulbs from amber to red, you have 2 choices: you can replace them with red LED bulbs or red bayont bulbs. For LED ones, you'll need the AUT1156-0ER-014V here: http://netdisty.net/ds/aut1157/ For incandescent ones, you'll need something like this: http://www.nextcollection.com/html/ORD-Lig...g-3686-none.cfm
(BTW. Last week, I ordered yellow 24xLED bulbs for the turn signals, and red 12xLED bulbs for the stop/brake lights. If they fit O.K., I'll be postinig pics showing the differences.)
Bury
Aug 18, 2017 08:15 AM
Gixerthou
Sep 1, 2016 04:52 AM
PhreshEmpire
Jun 8, 2012 03:17 PM
rb4065
Apr 15, 2009 01:46 AM
LostWaffle
Nov 3, 2004 11:56 AM
