Sponsored by: CARiD
License Plate LED installation
Old Apr 25, 2010 | 03:31 PM
s2kjae's Avatar
Default License Plate LED installation
I'm sorry if the answer to this question has been addressed before, but I tried searching and found no real answer.
How do I get the cover off the license plate light housing to install a led bulb?
Sorry for the noob question
Old Apr 25, 2010 | 03:40 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Just pry it off,with a small screwdriver,and pop it back in,after the replacement.
TheMuffinMan's Avatar
Two plastic tabs/clips on either side. One on left is in the middle of the light, one on right is towards the front of the car.
I used a small flat head to pop them in and down.
Old Apr 25, 2010 | 03:54 PM
slidingyellow05's Avatar
I just used a knife and proped it open from the back side of it. it was really simple. Just make sure that when you pull the old bulb out and throw in the new one that you test it before you throw the cover back on. Its normal if it doesn't light up. If this happens to you, just simply take the bulb out and turn it(changing the contacts) and install it back in. Test it one more time and it should work. As for installing the cover... it just snaps right back in. Hope this helps!
Old Apr 25, 2010 | 04:47 PM
S2k007's Avatar
Make sure its securely back in place though. I closed my trunk one day and the cover came off, haha.
Old Apr 25, 2010 | 06:07 PM
s2kjae's Avatar
Thanks guys, I just installed it
Old Apr 25, 2010 | 06:17 PM
Ap2batman's Avatar
I never put led lights in the rear but you should put led bulbs for clear sidemarkers if you want. I don't want cops to see my rear license plate so I just used regular light bulb. what color did you get?
Old Apr 25, 2010 | 06:23 PM
s2kjae's Avatar
I got them in white, its not too bright, but looks a lot better than the stock bulbs.
Old Apr 26, 2010 | 06:07 AM
takeshi's Avatar
I don't think a standard bulb will make your plate invisible.
pwrinxs
Jul 13, 2015 10:08 AM
rikkilambo
Feb 16, 2012 10:11 AM
Gizmo-R
May 13, 2009 11:28 AM
WPS
Mar 17, 2007 08:05 AM
REVHIR
Nov 23, 2005 09:57 PM
