Sponsored by: CARiD
low rpm hesisation
Old May 20, 2010 | 05:44 PM
ddonal2's Avatar
Default low rpm hesisation
Im not sure where to post this, but i think this problem may be due to my CAI intake, so i'll post it here.
I have a 2006 S2000 with and AEM CAI v2 and an Invidia q300 exhaust. I only have had the car for about 3 months, and i am noticing that the car has a "bump" or hesisation as i press the throttle at low RPM's.
Example: If i shift out of first into second at a low rpm range, and while in second, press the gas, their is a significant hesistation before the car gets going. I notice the same in third and fourth. It can almost be described as bad throttle response at low RPM's
Could this be due to my Intake or Exhaust?
Is this just how the car drives?
Any info would be helpful.
Thanks
Old May 20, 2010 | 05:46 PM
daicacharco's Avatar
Check your spark plugs. I've noticed the same thing with MY08. It was due to the fact that my spark plugs weren't very tight.
Now, i think I need to get a new battery.
Old May 20, 2010 | 06:00 PM
ddonal2's Avatar
what about the throttle position sensor?
Old May 21, 2010 | 03:35 PM
Monkeyboi's Avatar
I felt it when I had my K&N FPIK. Returned it back to stock and I feel it once in a long awhile. I'm thinking it has something to do with the sensor that's different on the 06+.
Old May 21, 2010 | 08:59 PM
OldDog's Avatar
I have the same hesitation at low RPM, I have stock intake. I'll be upgrading the spark plugs tomorrow. Recently did a compression test maybe the spark plugs weren't tightened enough. I will report back.
Old May 22, 2010 | 10:45 AM
pd0019's Avatar
i just had this problem on my car, check your spark plugs. one of mine were bad, i just went ahead and replaced all 4. fixed the problem for the most part.
Old May 22, 2010 | 11:17 AM
whiteflash's Avatar
Could be a number of things....
You could be running lean in the lower end of the powerband.
You could have an exhaust leak
Have you tried the map whack / clean?
Also, while it may not make a difference you could always try a ecu reset
Old May 22, 2010 | 04:58 PM
OldDog's Avatar
I just replaced the spark plugs with NGK Iridium and there's no more hesitation & engine runs more smooth. Old plugs had tips worn down bad, car only has 19k, I barely hit V-tec & don't drive the car hard.
Old May 23, 2010 | 09:03 AM
ABCVTEC's Avatar
It's probably heatsoak.
Old May 24, 2010 | 02:30 AM
dkat's Avatar
had a familiar issue i have an aem v2 as well i clean out my map sensor and problem gone!! i also check my spark plugs but those were g2g.
