low rpm hesisation
The '06+ AP2 has a big dip in ignition timing between 2K and 3K RPMs due to an increase in knock sensitivity in that range, and this causes a significant dip in torque. Increasing timing about 10 degrees at 2500 RPMs gave me about 13 ft-lbs of torque.
If you add that huge dip in torque at 2500 RPMs due to the ignition timing to the significant bump in torque at around 3500 RPMs due to the "resonant hump" that most CAI's have, you can get almost ~30 ft-lb difference from 2500 RPMs to 3500 RPMs. That can really make it feel like hesitation. Then heat soak makes this even more pronounced. Could this be what you are experiencing?
Since you have an '06, you should really consider getting a FlashPro so you can make your torque curve look more like this red line, and less like this blue line.
As soon as I read the title I guessed you have a 06+. Throttle hesitation at low rpm was the first thing I've noticed on DBW S2ks compare to AP1s. With FlashPro I loaded the non-TODA tune it came with and the hesitation instantly went away.
Originally Posted by cenix,May 27 2010, 01:36 AM
gernby,
that's a nicely tuned torque curve, especially for the 4-6k rpm range (i'm assuming the blue is before and red is after?). is this just with a flashpro tune?
Originally Posted by TougeS2k,May 27 2010, 02:10 AM
No offense but this thread makes me <3 my ap1
Originally Posted by gernby,May 27 2010, 05:13 AM
Thanks. The graph I posted above is just a before / after (about 15 minutes apart) of my current FlashPro tune compared to the stock tune.
It's very noticeable. When I flash the stock tune to the ECU, the power curve is very "lumpy", and the VTEC kick is annoying. Since I have a light weight flywheel, there's no way to keep it in VTEC between 1st and 2nd, so I have to feel the kick at least twice every time I accellerate hard. With my tune, it's absolutely smooth and strong from 2500 to redline.
