Sponsored by: CARiD
Lower VTEC with OEM cat?
Old Jul 27, 2014 | 10:29 AM
Apex1.0's Avatar
Default Lower VTEC with OEM cat?
So its about $250 for a used VAFC and harness. Everyone know these things are good for lowering VTEC and leaning out the mixture at WOT for best power. So, I will be running the OEM cat because of sound and emissions. My question is, is a VAFC worth it with the OEM cat? How much can I lower VTEC?
Old Jul 28, 2014 | 05:18 AM
Moddiction's Avatar
Former Sponsor
With stock cat you can't lower Vtec down much. At most around 5400 for engagement. I'd go with an actual engine management and get a real tune.
Old Jul 29, 2014 | 04:57 PM
odb812's Avatar
It's not worth it if you're stuck with the OEM cat, but it would certainly be worth it if you switched to a HFC. You should be able to pass emissions anywhere except CAs visual test with a HFC and I've never been able to tell the difference in sound. For less than $500($250 used VAFC + ~$220 HFC) I don't think you'll find anything else that will yield the power this combo will.
Old Aug 1, 2014 | 09:54 AM
Apex1.0's Avatar
I like the sound of the OEM cat. I will try a magnaflow HFC. I think that is the one berk uses.
devon2k
Apr 5, 2017 08:26 AM
06s2kid
May 17, 2016 02:22 PM
WRCGooseS2K
Jul 25, 2015 09:58 AM
