Sponsored by: CARiD
LSD for S2k
Old Feb 22, 2011 | 01:57 AM
instinct's Avatar
Default LSD for S2k
Hey all.
New to the S2k, and I hear that it has weak Diffs.
Ok i'm not that great with car mechanical stuff. I leave it all with my mechanics.
So when people say "Diffs" Do they mean LSD? And if I was to buy LSD is it just that one small part with lots of bolts and would that help with the common "s2k Diff" problems? OR am I mising something?
Thanks all.
Old Feb 22, 2011 | 02:49 AM
SOL1D's Avatar
I believe the housing itself is more of the weak point then the LSD itself. After the housing it's the ring and pinion. Just trying to remember off the top of my head, hopefully someone chimes in with more info or corrects me if I'm wrong.
Old Feb 22, 2011 | 08:45 AM
philbert's Avatar
If you are just driving on the street, the stock limited slip differential ("diff") should be plenty sufficient. The people that tend to have complaints are those who frequently track or autocross their car. Repeated hard launches will also decrease the longevity of your diff.
Old Feb 22, 2011 | 12:43 PM
instinct's Avatar
Thanks heaps for the replies!
Yeah I will be sliding the baby everynow and den, and doing launches as well.
I don't mind spending money on it, as long as I buy what I "need", as in I don't want to go and buy half of what I need, then find out that I need this other half of the piece to actually do a proper replacement...if you get me ><
Was thinking of getting a 1.5 way, but yeah don't know what's involved.
Thanks again.
Old Feb 22, 2011 | 01:36 PM
F22C S2K's Avatar
The main problem is the housing. It stresses easily under hard driving situations.
Our LSD is a Type B Torsen, which does not wear rapidly due to its use of parallel gears, compared to the clutch type LSD.
Every LSD has its advantages. Quaife LSD's and Torsen LSD's are both gear type but yet they act very differently. Same goes for the clutch type LSD's.
If you are serious about an LSD then do some research about them and which one will suit your driving style and how hard you drive.
If this is for a hard driven street car then a reinforced housing should be good, but while your at it you might as well get a new ring and pinion to manipulate your torque curve. Good luck and do a bit of research about rear end failures and you can find out if you need to upgrade.
Old Feb 22, 2011 | 11:59 PM
instinct's Avatar
Thanks man.
So it looks to me I should worry about the housing for now. I'll research more before buying an LSD though for now.
Thanks man =]
Old Jul 17, 2011 | 11:52 PM
blade_bunta's Avatar
Thanks again.
With a FR car I'd go with the 2 way LSD, usually 1.5 ways are seen on 4WD.. but that's just me
Old Jul 18, 2011 | 07:45 AM
kolyan2k's Avatar
wasnt LSD revised at some point on S2k ?
Old Jul 18, 2011 | 04:47 PM
starchland's Avatar
does going to a higher ratio gear set reduce the load on the pinion?
Wet_52k
Mar 24, 2013 07:32 PM
FlushS2000
Jun 15, 2012 09:58 AM
Dampachi06
Apr 13, 2008 07:42 AM
datchineseguy
Jul 10, 2006 03:13 PM
honda9krpm
Jun 12, 2004 05:51 PM
