lug nuts?
i am getting arp wheel studs and need to know what style lug, open-end, will work for
a stock ap1 wheel? most of the lug nuts say they will not work with stock wheels aftermarket only. can you guys help me out-cheers.
what are the length? if they are stock oem length then i don't see why shouldn't those work with stock lug nuts
if they are extended lug stud then you need open end lugs, they make those open ender for hub cap equipped honda(plastic cap or plastic enter cap for alloy)
you are right, aftermarket taper(60degree) end lugs are bad on OE rims.
my first car: acura legend 89' has those center plastic cap on the alloy wheel, the lugs is uber short to clear the cover and they are open ended and round seat.
Originally Posted by mikegarrison,Apr 11 2009, 06:35 PM
I'm told that lug nuts for almost any late 80s Civic, CRX, etc. will work. Basically, they all had open-ended lug nuts under pop off hubcaps.
chrome plated steel nuts, compact in size and weighted a ton
