Sponsored by: CARiD
Megan racing
Old Jul 2, 2010 | 06:35 AM
S2k Eire's Avatar
Default Megan racing
Hi all,
what are the two washers supplied on the balljoint end for, they are about 5mm thick.
Sorry I cant provide pics, hopefully someone that has fitted these will read.
Joe
Old Jul 9, 2010 | 12:14 AM
S2k Eire's Avatar
Bump!!
Old Jul 9, 2010 | 01:05 AM
Sinji's Avatar
depends on how low the car is, you put those washers in to set up the correct angle of the toe arms
Old Jul 9, 2010 | 02:16 AM
S2k Eire's Avatar
And I'm just dropping 1" on eibach springs - any info?
Old Jul 9, 2010 | 09:43 PM
Y2KS2K34's Avatar
if you are just dropping an inch you should have enough adjustment in stock components to make everything tidy...
atleast thats how it worked for me
Old Jul 10, 2010 | 01:59 AM
S2k Eire's Avatar
Cheers m8, thanks for the help.
Old Jul 10, 2010 | 12:18 PM
Nyther's Avatar
You have 3 washers, a big one and 2 smaller ones. the clue is to reposition the toe arm further away from the knuckle with the use of the washers, so that the bumpsteer will be reduced.
Some alignment shops have measurment tools for this, but i seey you have a '01 spec s2k with probably oem 16"wheels, so you cannot use all the washers otherwise you will hit the rim and might need to grind some off the lower nut to get the rims back on.
Old Jul 18, 2010 | 11:06 PM
S2k Eire's Avatar
I have 17" wheels on, tried with no washers and was able to get a 2degree camber minimum. I'll try with the washers next day off - bring the rear camber in some 1.7 - 1.5??
Mr-T
Dec 3, 2013 12:45 AM
boston5520
Mar 30, 2013 03:57 AM
Jetpilot718
Oct 30, 2008 10:46 AM
Ricgreen
Oct 6, 2007 12:20 AM
aaron002000
Jul 23, 2007 09:54 PM
