Sponsored by: CARiD
Modified S2000 Engine Question
Old Feb 15, 2017 | 05:18 PM
bjs2000's Avatar
Default Modified S2000 Engine Question
So I'm looking at an 2000 S2000 with a Turbo setup that is cutting out at high boost. My question is more about the engine. If compression is good and it was sleeved and rebuilt with 87mm pistons with a 9.1:1 compression ratio then can I only run boost on the car? Or could I remove the turbo and drive the car as is? Appreciate the help!
Old Feb 16, 2017 | 12:13 PM
EricLovato's Avatar
Buy an s2000 that isn't turbo already. Just my opinion. If you want N/A just like factory why even look at one that is already turbocharged?
Old Feb 16, 2017 | 12:20 PM
Aurex's Avatar
You can do what you said, the car will run fine with the proper tuning. But why would you? Save your time and find a car more close to OEM if that is what you want buying this car is ill advised.
Ravens
Mar 7, 2010 12:14 PM
jas825
Dec 3, 2004 09:05 PM
Shutoko S2000
Jan 19, 2003 04:43 PM
