My LED retro project
Originally Posted by Spec_Ops2087,Apr 25 2009, 05:48 AM
Being bright and being bright inside of a reflector housing are completely different.
These 3W Luxeons are known for their wide dispersion, as well, the bulbs all have radially mounted LEDs for full coverage to take advantage of the reflectors. If you do a bit of googling, you can tell that 3W LEDs are as bright or brighter than conventional bulbs, even inside the housings.
Originally Posted by SgtB,Apr 26 2009, 10:15 AM
You can modify the blinker relay to stop hyper flash. It doesn't make heat like the resistors do. I think modifry has a post about it on here. Nice mod btw.
No PnP bulbs will work correctly, there is a reason why they are not DOT approved. Yes the luxeons are bright but without proper optics they are useless and most reflector housing are not "proper" by any means.
Originally Posted by GTS Jeff,Apr 27 2009, 02:19 AM
You can also buy a flasher designed for LEDs...they sell ones that are straight PnP. Better option IMO because there's no chance of mutilating OEM parts and it's much faster and easier.
There is nothing wrong with the LED's blinking if you did as Spec_ops, and I did...
Very simple. Only 30 seconds per side, and $1.99 for each blinker.
20W 8ohm resistor in parallel with the LED
