Sponsored by: CARiD
Nardi wheel
Old Mar 1, 2011 | 05:07 PM
gravesdu_99's Avatar
Default Nardi wheel
Hey guys, I'm looking for some information about putting an aftermarket wheel in my car. I'm going to get a nardi deep corn, not sure if I should get a 330mm or 350mm. I was going to purchase a bell short hub and bell Rapfix GTC Pop-up Steering System. I would like to go with the 330mm, but I'm 5'10 and I don't want to block the tach at all. Is their anybody running this combination.
Old Mar 1, 2011 | 06:26 PM
Sinji's Avatar
the 330mm is close to the same size as the oem steering wheel. the 350 is a bit larger
Old Mar 2, 2011 | 05:04 AM
Will a 330mm allow the pop up system to work correctly
Old Mar 2, 2011 | 08:35 AM
S9735's Avatar
Diameter is unrelated with that, as long as you feel comfortable is fine. But I suggest not to get deep corn with quick release, because that'll make the wheel be to close to you. I have short hub + quick release + Nardi classic, the distance is just ok that I don't need to remove my hand from the wheel when signal. If being with deep corn you might have to. Pic here: https://www.s2ki.com/s2000/gallery/i...3-dsc03625jpg/
Have fun anyway
Old Mar 2, 2011 | 04:36 PM
s2kslav's Avatar
I also really like the deep corn but don't want the issue of it being too close, any way to solve the issue?
Old Mar 2, 2011 | 05:28 PM
s2sik's Avatar
the oem wheel actually is 360mm.
and yes originally i had the works short hub, works quick release and 330mm deep corn and you had to remove your hand from the wheel use the signal and it really bothered me. so recently i changed to the nrg short hub, works quick release, and the deep corn wheel and now it fits nicely. also i prefer the look over the accordion style of the works hub, the quality though is def not as good. id link you a couple pics but i have no idea how to operate this new site anymore, you can check it out in my build thread i the sig.
S2KBert
Feb 28, 2015 11:20 PM
mmhm
Jan 2, 2014 10:50 AM
CodyAP1Y2K
May 11, 2013 05:24 AM
moonliver
Jan 23, 2011 06:58 AM
robrob
Jan 8, 2009 07:07 AM
