S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
aftermarket steering wheel hub
Old Jan 2, 2014 | 08:17 AM
mmhm's Avatar
Default aftermarket steering wheel hub
currnetly looking to get a hub & steering wheel soon
was prob gonna pick up a nardi or personal wheel but as far as hub, i read people talk about 06+ throw out the airbag with nrg hubs so was gonna pick up a works bell probably.
but now question is, how far out would the steering wheel stick out wiht just a standard hub compared to a short hub without quick release? im guessing standard hub = short hub + qr combined?
thing is i want to keep stock distance from wheel to wiper/turn signal knobs but little further out i would not mind either..
so i guess im wondering, standard size hub or short hub? & if it helps, i'm planning on getting a 330 wheel
Old Jan 2, 2014 | 10:29 AM
Chris_Lum's Avatar
yes if you get a short hub, you NEED a QR or spacer. you wouldn't be able to use a short hub by itself unless you get a super dish wheel (and then it still might not work).
My WB standard hub with a flat wheel is pretty close to stock. If you can afford it, go short hub and QR. it's expensive, but the works bell short hub is much higher quality than the WB standard hub. the short hub is machined while the standard hub is cast aluminum.
Old Jan 2, 2014 | 10:50 AM
mmhm's Avatar
thanks for info!
CodyAP1Y2K
May 11, 2013 05:24 AM
gravesdu_99
Mar 2, 2011 05:28 PM
moonliver
Jan 23, 2011 06:58 AM
red 2000 s2k
Oct 19, 2009 06:48 AM
robrob
Jan 8, 2009 07:07 AM
