Sponsored by: CARiD
need help with EZ ON top fitment
Old Jul 18, 2011 | 03:29 PM
obriener2054's Avatar
Default need help with EZ ON top fitment
hi guys
i'm having trouble finding info on how to fix the issue i'm having with my top, cant for the life of me get anywhere on the little Island of Ireland
here's my problem, and how she sits
why is it sitting so high? this top is only a few months old, and i bought the car as it was....
i have more pics taken if they'll help with diagnosis..... so far all i've done is make sure the wire was connected\riveted both sides under the metal part at the front of the top
Old Jul 19, 2011 | 05:58 AM
TPhong's Avatar
I see that your car is either a MY00-01, so is it a rear glass conversion top? Could be possible that someone didn't install something properly.
Old Jul 19, 2011 | 06:01 AM
calhounhusker's Avatar
Im going to agree with this guy. I have the EZ-ON and mine sits a bit lower than that. Looks like someone just fubar'd the install.
Old Jul 20, 2011 | 09:58 AM
yes it is a 99 ap1 so originally a plastic roof...
so is it a case of taking off and refitting
Old Jul 20, 2011 | 11:03 AM
croftoncustoms's Avatar
There is nothing to adjust on the tops. Take the header apart again. Then make sure the cable is properly through the top, the frame, and is mounted with the correct screw. I have a feeling that it is wrong because the cable is what holds that part of the top down.
Feel free to PM me your number and I can walk you throughit by phone.
Don't worry. It will get fixed
Old Jul 20, 2011 | 12:00 PM
it's such a hassle as i'm in ireland....
so far i've taken off the first metal strip and ensured the wire was riveted in place....
where to go next, cant even think of mods til this is sorted
Old Jul 20, 2011 | 12:51 PM
Put the top open half way. The header should be straight up in the air. Along that edge of the top look to see if the cable is just flying around loose. If not the work your way to the edge of thetop before itmakes it's bend downward. You should see a small opening where the cable exits the top itself and goes through the frame and is the secured by a screw. You might not be able to see the secure point with the top still attached at the header but you should be able to determine if the cable is inside the top or not. Also, email me any pictures you have.
Croftoncustoms@hotmail.com
Doug
Old Jul 25, 2011 | 10:51 AM
well the wire is connected at the front of the top
couple of pics. bad news is the rubber seals are in a bad way
and i don't know if i'm missing fixtures here
and other pics
Old Jul 25, 2011 | 03:54 PM
SgtB's Avatar
The seals will press back in. Use a little silicone spray and the rubber will slide back into the channel easier. Make sure every bit of it is set or it will not seal right. Your seals are wavy because of that.
The cable runs through the fabric of the top. Are you ABSOLUTELY sure it's run through every eyelet in the fabric?
Old Jul 26, 2011 | 07:58 AM
put the seals in fine
is there an easy way to check if it's through the eyelets? sorry for the questions but unfortunately i bought the car as it is
