Need help with tranni dimensions
Hey guys, i need help with the measurements on the picture i have attached. I really appreciate it as i need it for a sequential trans that i am having built and don't have a trans to measure from. Thanks
I have a transmission in the garage, if no one is able to get to it before I get home
I don't want to be the person to screw your project up so I would appreciate it if you verified BUT I measured the input shaft, and, as shown, the INPUT SHAFT (not the stock piece that exists and appears similar to your diagram) is 22mm OD, and the depth from the edge of the input shaft teeth to the plane that the piece mounts to seems to be 68mm. The stock piece in this place appears to be 32mm OD and is 58mm or so deep.
PLEASE VERIFY THESE NUMBERS.
