Need New Clutch Assembly
Just took my 19000 mile AP1 to 2 different dealers due to clutch and shifting problems, the first dealer quoted me 6000 to fix her and the other dealer quoted me 3500. The second dealer I brought her too said I only need a new clutch assembly and clutch master cylinder. So I was wondering what was the best aftermarket clutch assembly to buy.
19k miles? Bad clutch? Is your car OEM? If so I find it hard to believe the clutch is worn unless you cannot drive manual transmission.
Is it slipping?
Shifting issues are usually fixed by bleeding the hydraulics and changing transmission fluid. Make sure it's the clutch before you throw money at it.
Is it slipping?
First, you probably don't need a clutch
Second, never bring your car to the dealership.
Find a shop that specializes in S2000.
First step, have the clutch fluid bled.
Second step, adjust clutch rod under the dash. There is a good youtube video on this. Only tool required is a 12mm open end wrench. Takes 5 min.
I bet clutch works fine after doing this. Shouldn't cost more than $100.
SloMant
May 23, 2018 02:15 PM
kasher_khan
May 18, 2016 04:44 PM
