Sponsored by: CARiD
Need Quick Test Pipe Help!
Old May 19, 2014 | 11:11 AM
macdaddies911's Avatar
Default Need Quick Test Pipe Help!
Ordered a berk 63mm test pipe it came with 1 3 bolt gasket.
My questions:
1. 63mm is the same size as stock exhaust right?
2. The other end of the test pipe is a 2 bolt opening, can I reuse the gasket since it did not come with one??
Old May 19, 2014 | 11:22 AM
vtec9's Avatar
63mm is the version you want with stock exhaust.
The 2 bolt end used spring bolts, and the donut gasket. You can re-use the gasket. Be careful when removing the spring bolts. If they are very rusted, they can bent when being removed.
Old May 19, 2014 | 11:25 AM
baZurk's Avatar
Old May 19, 2014 | 11:35 AM
Thanks guys!
Old May 21, 2014 | 09:58 AM
Gernby's Avatar
Former Sponsor
The stock exhaust is 60 mm, so it's actually better to get a 60 mm test pipe, or you'll get a bigger dip in the midrange torque with VTEC lowered.
Old May 21, 2014 | 05:34 PM
Dang I got 63mm. Hopefully 3mm won't make a crazy difference. Gernby how loud is your exhaust compared to stock?
Old May 22, 2014 | 06:49 AM
vtec9's Avatar
63 is all berk sells for OEM exhausts (63.5? i think), so you'd have to go with another manufacturer I've run one since they were first released.. over 150k miles.. you won't know the difference.
EK9MAX
May 16, 2010 10:58 AM
S2kRally
Nov 13, 2009 04:45 PM
amkaluta
Sep 4, 2009 06:15 PM
Bliss@5200
Apr 27, 2007 01:14 PM
