Sponsored by: CARiD
OEM Clutch Disc w/ Lightweight Flywheel
Old Feb 9, 2009 | 11:53 AM
RedSex2k's Avatar
Default OEM Clutch Disc w/ Lightweight Flywheel
Hi all, I've done some research but haven't come up with a definitive answer on this yet. I'm looking to upgrade my flywheel to a lightweight model from either ACT or CM, and upgrade the pressure plate as well. I just wanted to know if I can expect quicker wear on the OEM clutch disc with this setup, or if it would be cancelled out by the added force of the pressure plate. According to what I've read, ACT uses rebuilt OEM discs and offers the flywheel I was looking at, so it seems it would be safe. Any insight or experience would be much appreciated.
Old Feb 9, 2009 | 12:44 PM
ans2k's Avatar
quicker? not any if you drive it right! if you are not used to driving with a lighter flywheel then maybe. and you probably can take that CDV out too.
Old Feb 9, 2009 | 01:10 PM
Kermdaddy's Avatar
Just buy a used AP1 flywheel and have it resurfaced.
Old Feb 9, 2009 | 01:25 PM
RedSex2k's Avatar
How much does the ap1 flywheel weigh?
Old Feb 9, 2009 | 01:57 PM
ans2k's Avatar
i think about 13 lbs
Old Feb 9, 2009 | 02:12 PM
camuman's Avatar
ap1 flywheel FTW
Old Feb 9, 2009 | 02:37 PM
JoeS0Fly's Avatar
id stay with the oem flywheel, (ap1 flywheel that is)
its gonna be a bitch to move on a 11lb (or lighter) flywheel.
Old Feb 9, 2009 | 03:11 PM
TJ01s's Avatar
not really, I have a 9.5 lb flywheel, and I noticed no difference in any way from the stock one. not driving, revving, nothing. pretty sad when youi pick both of them up and the aftermarket one is WAY lighter!!
If you do decide to use a lightweight fly, make sure it is a chromoly steel one, aluminum ones tend to warp if heated a little too much
oh yea, i have an '01
Old Feb 9, 2009 | 04:05 PM
cdelena's Avatar
I have an 8lb Toda and I did notice the difference immediately. I would not go back to the heavy OEM FW.
Old Feb 9, 2009 | 04:09 PM
JoeS0Fly's Avatar
ahh i c. i stand corrected!
thank you guys.
