Sponsored by: CARiD
OEM hardop removal plus Hardware Kit
Old Nov 23, 2013 | 02:11 PM
Ihaveits2k's Avatar
Default OEM hardop removal plus Hardware Kit
Hi Everyone!
Question:
1. Is it easy to remove the hardtop & hardware kit?
2. Do you have to mess with wires, front latches, etc. on the car?
3. Will removing the hardtop and hardware kit damage anything on the car?
Thank you so much in advance!
Old Nov 23, 2013 | 06:25 PM
AZS2KDancer's Avatar
It's easy to remove it. Just four catches, the two on the windshield and one on each side right behind the seats, like quick release levers. There will be some connected cables (wiring) that has probably grey connectors that you unclip on the driver's side for the defroster (do this before you and your friend lift it off). Yes, you need a helper, as the weight is not the issue, but the bulk size of it is usually too big for one person to handle.
CynicG
Feb 1, 2017 01:18 PM
I.tamdinh
Aug 13, 2012 12:43 PM
