painting stainless steel mufflers
I'm not a fan of the shine on my stainless steel aftermarket exhaust mufflers. I'd like to paint the mufflers flat black.
Any special tips? I was thinking of scuffing the surface, cleaning the surface and using a automotive hi-temp paint.
Should a use an etching primer first? if so, is the primer rated for hi-temp?
Thanks
Thanks
The paint will stick as long as you scuff the surface a bit. I would suggest you use the higher temp paint. Autozone and pepboys sell various brands of hi temp paint and the lower rated one has burned off of some exhaust work I painted in the past. I would try the higher rated one first if I were you.
I have a used Mugen exhaust, the pipes showed light corrosion starting from the salt air here. Scuffed it with a Scotch Brite green scouring pad, degreased with brake cleaner and put on 2 coats of VHT header paint. So far the only issue is it getting dirty but I went with white to track if the corrosion progressed, which would discolor the white.
Site Moderator
Yup vht or duplicolor height heat. Stuff works great. I painted my exhaust, header, wheels, and valve cover with it. Just clean it well and apply multiple coats.
