Sponsored by: CARiD
password jdm intake
Old Feb 24, 2013 | 02:52 PM
OMGas2k's Avatar
Default password jdm intake
what sup guys so it was my birthday on the 16th and i spent all my money on a password jdm intake and a test pipe.the test pipe is a invidia 70mm and it went on no problem and it hasn't thrown a cel yet. it sounds awesome and im very happy with it. Name:  allforsosa245_zps2aa0806e.jpg
so now lets move onto the PWJDM intake. it took about 2 weeks to get here and when it got here i instantly started the install with my dad.Name:  allforsosa256_zps2dd4a8bb.jpg
Size:  106.0 KBso the actual intake went on with no problems but then we got to the part of putting on the snorkel and the power camber. it went on and i couldn't wait to drive away but then the hood wouldn't close. so we adjusted the hood latch and it fit but it left me with a little gap on the left side. im very dissapointed in PWJDM because they said it would fit with no hood cutting or adjustments required.apart from the gap it sounds awesome and i can definantly tell the power increase and throttle response.here so of the pics of it on and the gap.Name:  allforsosa280_zps66abdbf7.jpg
Size:  98.0 KBName:  allforsosa281_zpsb91ebed8.jpg
Size:  56.0 KBName:  allforsosa282_zpsb18a6178.jpg
Size:  108.8 KBName:  allforsosa297_zps1a073372.jpg
before we removed the rubber plate under the screws that hold the front bumperName:  allforsosa333_zpsafda05eb.jpg
after we adjusted everything. not to bad but still not perfect.
Old Feb 24, 2013 | 03:43 PM
Sterling Sackey's Avatar
One thing I've read that may help is loosening all the bolts, getting it into an optimal position, then re-tightening the bolts while someone holds the intake in that position.
Old Feb 24, 2013 | 04:51 PM
Utah S2K's Avatar
I run this intake and love it. But getting a good fit is a bitch. Loose n tighten, tighten loosen and you can get close. As previously noted loosen the screws (snorkel) and try a variety of positions. The key is to pin the snorkel flat with one hand while tightening the mounting bolts. You can then adjust the hood latch by loosening the mounting bracket and adjusting it up a hair. These two points should get you as good as you can get it. Also don't slam the hood or you'll have a bunch of fiber mat. Many have destroyed this work of art by letting a mechanic or friend drop the hood. Once adjusted you have the best intake on the market(IMHO)........and I have tried many.
Utah
Old Feb 24, 2013 | 08:56 PM
OMGas2k's Avatar
Utah
yeah man im in love with it. the sound it produces is beautiful and the little gap doesnt bother me too much. and thanks for the tips il definantly try it out.
Old Feb 24, 2013 | 08:57 PM
OMGas2k's Avatar
Originally Posted by RidinLoooooW
Not a bad way to spend your B-Day money
haha i agree
Old Feb 25, 2013 | 12:00 AM
realblag's Avatar
Just cut out the hood and be done. No gaps. I did this with a Dremel tool with the hood still on the car. This was to clear for my Mugen airbox but the same will work for the PWJDM.
Old Mar 16, 2013 | 03:14 AM
Wael El-Dasher's Avatar
What about the hood prop? Does it have to be removed and replaced with hood shocks?
Old Mar 16, 2013 | 01:17 PM
aston19uk's Avatar
what's the improvement over standard? price. Looks bubbly and smoothy in a good way
Old Mar 16, 2013 | 03:43 PM
OMGas2k's Avatar
you have to remove the hood prop and you can replace it with hood shocks but i just keep the hood prop in the back off the car and then whenver i need it to stay open i get it and put it in
Old Mar 17, 2013 | 12:07 PM
Thanks OMGas2k. I'm intrigued by the design. Looks very neat. I think I've found the intake I'm getting now. Thanks for the info.
cheers
Wael
