PIC REQ.SIDE MARKERS ON
Hey whats up s2ki,
I want to know if the side markers could stay on and flash at the same time without
using any custom parts only if its possible if not plz lmk....thnx
So I am guessing that you want to have the side markers on all the time, then when you indicate it turns off the back on (flash). Then once you have finished turning then it turns back on??
Could maybe do a NOT Gate control system with a relay?? Just hook up to invert the signal from the flasher unit so the light is one when there is no signal coming from the flasher unit??
Hope you can read the drawing. It's a 510 ohm, 1/2 watt resistor and 2 1N4001 - 1N4007 diode. You need to make one for each side. You can go up or down on resistance to vary the output. This will allow the side markers to stay lit all the time and flash completely on and off with a turn signal feed. I recommend LED bulbs whenever doing this conversion because the bulb will run hotter since it's always on. If the housing wasn't designed for a "constant-on" bulb, they may distort from the heat. LED's run nice and cooool!
