Sponsored by: CARiD
Piolk Designs - eBrake Button
Old Nov 29, 2018 | 03:57 PM
jimmyfu's Avatar
Default Piolk Designs - eBrake Button
Has anyone succesfully installed one of these buttons on their e-brake? I took off my button yesterday and tried to install it, but it seems that the threads were too short and couldn't catch. I have a 2005 S2000 if that matters. Sent an email through their form last night and still no response...
Old Nov 29, 2018 | 11:11 PM
silenc3x's Avatar
Yes, I did pretty easily. Like within 30 seconds. I had a harder time removing the stock button with wrenches and shit, but got it with a vice grip. Just needed a good enough grip on it.
I also have a 2005.
You kinda need to push down the button as you screw it in. It'll catch. Try again, you got it!
Old Nov 30, 2018 | 03:23 PM
jimmyfu's Avatar
It seems that the rod inside that's supposed to thread onto gets pushed back even with the gentlest touch...did you have that issue too?
I also have a 2005.
Old Nov 30, 2018 | 03:49 PM
silenc3x's Avatar
You should be able to still screw it in when it's pushed down. It seemed to be on a spring, and I wasn't able to screw it in until the spring was fully engaged and all the way down.
My ebrake was pulled all the way up and I was parked. Not sure if it makes it any easier but that's what I did.
Old Dec 2, 2018 | 08:13 PM
jimmyfu's Avatar
Got it! Thanks for the encouragement! However - new issue. Sometimes the button doesn't spring back all the way to lock. Not sure if this is the e-brake or something getting jammed inside the handle track? Not sure how to smooth it out either. It started doing this even when I had the stock button put back on when I couldn't put the Piolk button the first time around
Old Dec 2, 2018 | 09:26 PM
silenc3x's Avatar
It may not be screwed in all of the way... or possibly a small piece of plastic from the previous button broke off in the brake assembly. You could try unscrewing and looking in there with a flashlight then try rescrewing until it's tight. Spring also might be set weirdly. All things to consider.
Old Aug 24, 2019 | 03:40 PM
Iilac's Avatar
Hope you guys can help. I am attempting to take off the Ebrake button on my 06. I am using vice grips and the button turns but it's not coming off. Can you provide some pointers?
Old Aug 24, 2019 | 04:21 PM
Iilac's Avatar
Got it. I just had to continue the use of my vice grips on the button until it came loose.
AP2
Aug 19, 2009 04:52 PM
rustywave
Aug 16, 2006 08:22 AM
Mannn
Jan 13, 2006 01:44 PM
Nabs 79
Dec 1, 2004 09:14 AM
JetBlackS2000
May 19, 2004 08:57 AM
