Please I beg someone help me lol...
Well I had the body shop install AP2 tail lights and I have to do the wiring myself. Not a big deal but during the triming of the AP1 Clips I broke it and found it easier to break the clips off and individually wrap them and clip them. Well in doing that I mixed the wires and do not know what wires go in what order and need pictures or just info. Either from AP1 or 2 it does not matter.
Basically I need the order from top to bottom on these clips. Please do both sides so I know that they are exact same from top to bottom because it would suck to have it go red, white, black then on the other side go black, white, red lol.
Bump before bed. Please someone it may take less then 5 minutes for someone. I will be trying to figure the wiring out in about 4 hours and am hoping I wake up to someone already answering this. Thanks in advance
Originally Posted by dagle,Feb 5 2009, 03:56 PM
ill see if i can do it in a little bit when the little kiddies go home
You can use a meter to find voltage on each pin. Hit the brakes, turn on the blinker, put the car in reverse, etc. Once you know those you can run a jumper off the blinker line and find which pin lights up what in the housing. They should all be 12v, so it won't hurt anything.
duh..just realized what you where asking for:
AP1 with the retainer clip facing up:
Larger tail light clip - Black, Red, White
Smaller tail light clip- Red, Black
Turn signal - Green/Yellow, Black
Reverse - Green/Black, Black
Looking at the tail light colorings, it looks like the white is the only unique wire to that group. A continuity test will tell you if the reds and blacks are all common. I do have pictures if it would help.
