Possible to change the 6th gear
You can go get a 2009 Toyota Corolla with a 4 cylinder that will cruse down the highway at 70mph and get 34 mpg at 2450 rpm's.
If you think rpm's don't affect gas mileage go put 4.77's in your car and take a long drive and see what your gas mileage is.
I would love to see a tall 6th gear so my '06 could cruse at 75 mph at 2600/2900 rpm's instead of 4000 rpm's as it does now.
Keep the bottom 5 gears for the track and 6th gear to get you there and back with more comfort.
If you get a Corvette that was built after 2000 you will pull 30+ mpg just cruising down the highway at 70 mph.
You would also put a lot less wear on the engine with a taller 6th gear to the tune of 78,000 less revolutions every hour in high gear with a gear that would lower the rpm's to 2700rpm's @ 75mph.
ROD
Originally Posted by whiteflash' timestamp='1302112331' post='20436610
RPM's don't really matter in MPG....
Your friends corvette also isn't getting the mpg you're getting....
ROD
You're better off adding airflow, tuning at a leaner afr (less fuel), and increasing timing to achieve more power @ less fuel = more mpg.
You're right about wear and tear, but that's not what this thread is about. Its about the misconception that RPM's are more important that throttle plate/position, and how much fuel is being dumped in how fast; which is independent from RPM's. According to my Hondata logs, I input less fuel at a constant 8000 rpms than I do at 4000 rpms. Maybe I suck at correlating things, but if ceteris paribus (no other variables changes) I should get a better MPG at a higher RPM. Of course that's not counting the fuel wasted to get up to 8,000rpms; or if I want to change speeds.
Be my guest go cruse at 8000 rpm's you will suck fuel so fast that you won't get 200 miles on a tank. Out in the real world(on the street or race track)if you want to stretch your mileage you lower the rpm's, out on the race track you suck right up to the rear end of the car in front of you so he runs out of fuel(he pulls you) and you don't use as much fuel or you lower your rpm's if you have a good size lead to save fuel.
I have a bike that has a small gas tank so when I go to reserve I lower the rpm's(and speed) and I can change my mileage so I get 49 mpg instead of the 38/40 and hopefully make it to the next gas station.
That(lower rpm) is why the auto manufacturers had the stick cars skip gears to meet "Federal gas mileage requirements", don't you think if high rpm's got better mileage they would have made the cars do that? But not one auto manufacturer has done that, are they that stupid if it(lower rpm's) didn't save gas then why make the car skip gears and spend all that money to make the transmission skip gears?
Like I said I like the first 5 gears in my "S" I just wish that 6th gear was higher.
ROD
ROD
A corvette has twice as many cylinders too, so the combustions per minute is twice as high as a 4 cylinder. However, they do get better MPG than an S2000 due to improved aerodynamcs.
If you get a numerically lower final drive (big bucks) or an AP2 transmission, you'll definitely get better highway MPG. However, depending on the exhaust you have, drone could be better or worse. Every exhaust drones, but the RPM that they drone at varies from one to another.
If this is about mpg's then this thread is worthless. The money spent on actual replacement gear plus installation would be way more than you'd ever spend on gas by lowering 6th gear rpms 500, 1000, 1500 rpms.
If this is about lowering 6th gear rpms to make highway driving more tolerable your logic is sound.
And to Whiteflash, Vettes can easily do 30mpg on the highway all while loping around at ridiculously low rpms for the speed.
Sorry but both of those statements are
ROD
ROD
Sorry but you're quite wrong, MPG isn't inherently correlated to RPM's. And there's a reason why I said 'don't really matter'. If you hold cruise control at 7k, and cruise control at 4k you're not going to see a difference. Where you're going to see a difference is in the Throttle plate / throttle position / AFR position. So no, RPM's don't really affect MPG. Although the amount of throttle you use to get to a higher RPM, and the amount of throttle you would need to accelerate past that, is what's going to diminish your mpg.
If you really want to test this theory drive your car around and never go into 5th/6th gear. Then tell us how much worse your fuel milage is. Since you will be encountering many different driving modes in 4th gear whether or not your cruising wont be a factor. The last person who argued this point never tried this!!!
Also, if you werent already familiar with the tuning on our cars they are already tuned as you have suggested, Honda already thought of that.
To the OP, i had already brought this up at the beginning of the year, after a few pages of arguing points of fuel economy. a solution was found but i have yet to tackle the project yet. The solution is an AP2 trans with an AP1 output shaft and 6th gear. Basically a hybrid trans. this by way of math would reduce rpms by a few hundred. if you then Install taller rearend gears(will make your car accelerate slower) you can get the RPM drop you desire.
https://www.s2ki.com/s2000/topic/838...#entry20043415 ENJOY!!!
Also vettes have WAY more power and tq. They can get away with low gearing. I think they have 3.55?
I could be wrong but I would think RPM matters, because you are squirting more fuel in the cylinders
