Power gain by weight ?
Hi !
I want to know if there is a power gain in replacing the soft top by a hard top...
I suppose that the hars is lighter
And wich HT is lighter ( oem or mugen style )
Thanx
OEM HT is 44lbs.
You should do a search, this has been covered. You can gut the softtop and motor and everything and I *think* I remember reading it would save you 40 or 50lbs even with the OEM HT installed, but I may be wrong.
not a power gain you'll increase your power to weight ratio, braking, handling, everything but it'll only be a 30 pound difference so it wont do much but if you remove spare and tools get exhaust everything starts to add up.
also mugen CF is lighter
Originally Posted by iam7head,Apr 4 2009, 02:22 PM
also factors in the aerodynamic advantage, esp when most of the track requires you to lower your soft top on the track
The OEM HT is a great mod and you can always easily sell it if need, esp when your car is black like mine.
