Sponsored by: CARiD
Prepping front lip for paint?
Old Feb 21, 2008 | 07:36 PM
lude9285's Avatar
Default Prepping front lip for paint?
Hey guys i got lip ive been wanting for while but its GPW and i wanted to know what grit sand paper, procedures, etc. to get it ready before i take it to the body shop. Id like to prep it as much as i can to save some cash before i take it to be painted/
Old Feb 21, 2008 | 08:51 PM
hondata1's Avatar
I would use 600 dry if it's not primed then if you have any primer put a few light coats and sand it wet with some 1200 . You might not save any money bec, every shop likes to do it a different way. Also if the paint starts to peel they might blame it on you because, you prepped it for paint. I would just leave the hole job for them .. When I used to paint for my body shop I would not start something that someone already tried to work on .
Old Feb 21, 2008 | 09:04 PM
lude9285's Avatar
yeah..you re right. Thanks for the advice.
ill just take it somewhere an get a quote
Old Feb 21, 2008 | 09:54 PM
iam7head's Avatar
hondata is right, we don't like to do follow up job, sometime a client coming in with a prepped part(with good intention) and we end up doing double the work.
it really depends on the finish you have right now, if you have a new oem painted lip with zero miles, the prep work only consiste of light sanding the lip(wet like always) basecoatd and clearcoat. the sanding is cross hatch action for max mechanical adhesion
if you have a scratch or cracking paint on the current lip, we have to take it down to the ecoat/material, primer,sealer, basecoat and clearcoat
if you have no idea what i just said(which is pretty normal) just have them do it.
Old Feb 22, 2008 | 01:32 AM
hondata1's Avatar
If you know someone it should not be more then $100.. That's what I would charge for someone I don't know but , I always had good prices. And that is maybe sealer if it needs it but, it
Old Feb 22, 2008 | 01:39 AM
hondata1's Avatar
Owwww I used to know alll about double the werk lol...
Yeppp You are 100% on the money ... Also if you have any scratches or cracks and if they are more deep then your finger nail.. Make sure the fill it with some kind of icing .. I use to love people who used to love and finger Fock things to try to get it out..
And see if they are going to wetsand and polish your lip after it done.. If it has any dirt or fisheyes and a lot of orange peel . I like my work to look like glass when it's done ..
Old Feb 22, 2008 | 08:50 AM
lude9285's Avatar
thanks for the advice guys....i have a oem bumper in my garage in primer along with the lip i need painted. What should i expect (approx. cost) to get both painted?
Old Feb 22, 2008 | 09:11 AM
lude9285's Avatar
also i wanted to fill in the holes from the honda emblem and front plate plugs. Is that also something i should let the shop do? i was just going to mix up a little fiberglass and fill the holes
Infantry_S2k
Jan 10, 2013 09:58 AM
dc5type_S
Feb 21, 2008 06:20 PM
trainwreck
Dec 19, 2007 11:56 AM
jal3lee
Jun 12, 2006 08:05 AM
owenxguo
Dec 8, 2003 06:48 AM
