Qube Cluster LED Colors
I liked the look of white but I thought it would be too bright at night and all the other bulbs in the cabin are orange-like colour. The LED upgrades are such a boost in light output you don't get a lot of dimming in the night setting, so they are very bright.
I had mine upgraded and I went with an amber tach and red speedo, red temp gauge, red fuel gauge. I got mine done by Jordanksartell (fellow member here) in TN, his LED upgrades use the oem power supply so you don't have to run a separate power supply to the spare fuse slot. More of a plug and play setup which I liked.
I did something similar but only cost me $5 to do. I did it using the stock bulbs and just used some semi transparent binder dividers to get the colors. Not very bright in day unless you hold the dash brightness button to make it very bright if you run the headlights during the day like me.
The LED ones I am sure will be nicer and brighter but for $5 can't go wrong. Had this for a couple years already no with zero issues. Can do them all red as well which would be MUCH easier than doing the multi color.
