Sponsored by: CARiD
Radiator
Old Feb 17, 2008 | 10:07 PM
Rick006's Avatar
Default Radiator
Does anyone know if there is a lighter radiator available for the s2000?
Old Feb 18, 2008 | 07:01 AM
skibum's Avatar
Most of the replacement radiators hold more coolant which would make them heavier. The radiator empty is not that heavy. Get a lightweight battery if you are looking to shave lbs under the hood.
Old Feb 18, 2008 | 11:45 AM
Tyraid2K's Avatar
aluminum is lighter than the copper radiator you'll find in the stock unit, however it is true that higher capacity means more weight,
I lost weight when i did this mod though because I got a radiator that replaced the two stock fans with a single thin spal fan, the weight of the stock fans is really surprising when you remove them,
so yes, there is weight to be saved
Old Feb 18, 2008 | 01:32 PM
U9aXy6Dn's Avatar
weight is in the detail
bigger rad, better cooling but fit titanium holders, slim-line fand and so on and you start to make up points again
wanna lose real weight, buy a carbon girlfriend!
Old Feb 18, 2008 | 01:38 PM
Rick006's Avatar
Can you tell me what combination of radiator and fan I need to keep my 2.5 liter cool and AC working well and still drop at least 5 lbs?
Old Feb 18, 2008 | 01:39 PM
Rick006's Avatar
Ok, I see "slim line" but what about the radiator?
Old Feb 18, 2008 | 01:41 PM
Rick006's Avatar
Ok, If i go to the slim line fan and put a cooler thermostat and switch in it will my AC be a little cooler due to the slim line kicking on more often?
Old Feb 18, 2008 | 03:43 PM
vividracing.com's Avatar
Banned
This is the truth, the fans are the fattest part on most cars cooling system... Plus they dont pull near as much air threw them as say a slim line.
kbmass
Jul 1, 2011 09:34 AM
ATL_S2K
Jan 15, 2010 02:08 AM
KIDS2000
Sep 1, 2003 11:16 AM
Ex Con
Jul 10, 2002 04:56 AM
