Rear Overs
Does anyone have a somewhat detailed description on the installation process of these bad boys. I just picked up a set from Go Tuning and need some help.
How do they attach- Dzus fitting? Anybody have item number for theses.
What type of foam do you guys spray on the underneath side? I am just worried about rust?
Let me know
thanks for the help
Let me know
thanks for the help
You're suppose to cut about an inch of the quarter panel out at the top of the wheel arc. Like a 1/4th moon sliver. Then you just tack/rivet the over fender on so it matches the rest of the wheel arc.
If you are looking for looks only, no need to cut the fenders. If you are going for a low offset wheel set up, you would need to cut the fenders to clear the tires. If you are cutting I would suggest painting so there is no rust buildup overtime.
