Sponsored by: CARiD
Header questions
Old Jan 31, 2008 | 12:08 AM
00S2Ked's Avatar
Default Header questions
Ok i am thinking about purchasing an aftermarket header but before i do. When installing the header is reflashing or a new ecu required? i figure not but i just want to make sure..
Old Jan 31, 2008 | 04:54 AM
S2KPUDDYDAD's Avatar
No, It is a good idea to reset the factory ECU by pulling it's fuse or disconnecting the battery.
One reconnected let the car idle for 2 minutes
Old Jan 31, 2008 | 06:57 AM
cdelena's Avatar
The stock header is pretty effective so you will see minimal (if any) change with an aftermarket unit. You may want to consider using those funds elsewhere.
Old Jan 31, 2008 | 07:15 AM
AP_ONE's Avatar
also with a aftermarket header, you might want to get lets say a apexi i vafc to tune it a bit. The oem header is very good, a bonus to swap it out is for weight savings, usually about 10-15 pounds lighter.
best of luck with your choice
xxyion
Mar 19, 2019 05:29 PM
wildcardtrd
Nov 4, 2015 05:48 PM
Dicktp
16
May 16, 2012 07:13 AM
REVZ TO9
Jun 28, 2006 01:22 PM
