Removed CDV, still slipping
So the CDV starting making my clutch slip/float like crazy after putting on some wider stickier tires. I removed it and it didn't really seem to help any. After doing some more research is seems that the PP and/or flywheel is to blame. The only problem is i also read that a lighter weight flywheel causes rpm's to drop so fast that i may fall outside of vtec during shifts.
My car:
MY08 ap2
+FIPK Intake
+70mm HFC
+70mm T1R EM dual
+SSR type C wheels 17X8, 17X9 wrapped in 225/45 and 255/40 Z1 starspec tires
+CDV removed
My planned future mods:
+Act PP i think?
+Aftermarket clutch (not sure which one but only slightly more aggressive, help?)
+AP1 flywheel
+Hondata reflash (to fix the drop out of vtec issue that results from a lighter fly. I want the reflash without header. Just want a bit more vtec. Too low of vtec i feel like we are trying to make this car drive not such much like an s2k. Also I do not want to buy a piece of crap expensive header when the stock is just fine)
+AP1 intake cam (to take full benefit of the higher rev line)
So what you guys think of my solution?
My car:
MY08 ap2
+FIPK Intake
+70mm HFC
+70mm T1R EM dual
+CDV removed
+Act PP i think?
+AP1 flywheel
The pressure plate is the root of your problem. In the early years, the pp was widely acknowledged as the weak point in clutch grab. The addition of a CDV in the AP2 confused the issue for most people, but it's still there, as you've found out. The Act PP is a great choice to improve clutch grab, but I would keep the stock friction disc. It's perfectly adequate unless you're making serious hp mods (FI).
I plan on getting a S/C is the distant future if I get bored. So i figure a clutch upgrade would be good to set that up since i would have to drop the tranny anyway.
Any recommendations? It seems that people dont think as highly about ACT clutches as they do of their PP.
Originally Posted by a_zepeda926,Mar 29 2009, 11:28 AM
The flywheel is also part of this issue, however with the ap1 flywheel you should be good.
i dont see how the flywheel makes a difference or not, as far as staying in vtec. sure it lets the revs rise/drop quicker, but when you're shifting, its actual road speed that determines what RPM you will be at in the next gear.
as far as clutches go, i had a fidanza 8lb flywheel and kevlar clutch disc kit in my prelude. i loved it. too bad they dont make one for the S.
