Removed CDV, still slipping
I am just going by what ive read from a few different people with the rpm drop. I was told that going from an ap2 flywheel to a lightweight one that revs drop so fast that you need to shift lightening fast in order to stay in vtec or it will drop an additional 500 rpms. Maybe they are just bad drivers i dont know. I didnt even think about the road speed, that makes sense.
I guess i will need to do this soon. After putting on some stickier tires my clutch slips so much that i dont even want to revline it anymore.
Originally Posted by wonderd,Mar 29 2009, 02:23 PM
ap1 flywheel, act pp, oem disk, and you will still be fine on a supercharger
if you take any stock ap2, and shift from 2nd to 3rd you will notice that you went from 8000 to about 6000. so getting a lighter flywheel, will have less mass and have less inertia so it will make the rpm drop quicker.
i do like your future plans for na but fair warning, using a ap1 does give you better peak hp but the non-vtec lobe gives you less torque. and matching the ap1 intake cam, you should use the ap1 exhaust cams too. the cams work in pairs. ap1= good peak ap2 = good low/non-vtec torque. ap1 flywheel is alot cheeper, i think, than other after market flywheel, act flywheel is about $600. and as for the reflash, there are some people who has gotten the toda reflash without a header.
and if you will be going towrds a s/c, you might want to look into getting a "buy a piece of crap expensive header" since you could get about 15-20 hp for it, if you're going s/c.
Either way i am going to hold off on the reflash a bit. My clutch is way too annoying and needs attention before anything else.
Christian Baril
Mar 8, 2013 11:43 AM
