Sponsored by: CARiD
Removing the airbag system.
Old Dec 23, 2010 | 06:22 PM
jsenclosure's Avatar
Default Removing the airbag system.
Does anyone know if i remove the entire airbag system will the light go on? If the light does go on is there a way to keep it off with the airbag system removed?
i am caging my car so the air bags will not be needed.
Old Dec 23, 2010 | 06:27 PM
dan_uk's Avatar
yea it will go on the SRS light.. I just ignore it its not annoying for me like the CEL
Old Dec 23, 2010 | 08:50 PM
ahrmike's Avatar
you can wire in a resistor into the system to fool it into thinking the bag is there.
The SRS system includes the seatbelts which auto-retract and freeze, might want to think about that too
Old Dec 23, 2010 | 09:37 PM
I want to remove everything, all bags and seatbelts
Old Dec 23, 2010 | 09:40 PM
ahrmike's Avatar
Ok, I'm not sure how well it'll work but you could try the resistor trick on everything.
However, I know the SRS ECU (under your radio) is one time use, so I'm not sure if you trigger it (collision, hard bump on track...?) if the SRS light will stay off.
you could just pop open your gauge cluster and pull the SRS light and the entire system? (seatbelts, airbags, ecu?)
Old Dec 24, 2010 | 05:09 AM
Here in ny you cannot have any lights on for inspection. Even if I pull the light, it will still show up on the obd2 reading
Old Dec 24, 2010 | 05:11 AM
ahrmike's Avatar
Ok, then I suggest just using the resistor trick, the resistance value is on this forum somewhere.. Just make sure you dont set off the SRS ECU, or purchase a few from people who don't need it
Old Dec 24, 2010 | 06:30 AM
Sinji's Avatar
You need a 2ohm resistor. my momo hub came with one. you can find it on ebay or you can make your own
heres a link if you need more info:
http://www.honda-tech.com/showthread.php?t=2398113
Old Dec 24, 2010 | 07:18 AM
I want to remove Everything, so the resistor trick for the steering wheel won't work for me i'm pretty sure. i am pulling out all bags, seatbelts, all wiring and srs ecu. How do i keep the light from comming on?
Old Dec 24, 2010 | 09:33 AM
IAmTheRealAsif's Avatar
I hope you have a roll bar, harness bar, a bucket. To be safe I mean
