Renegade Motorsports Short Throw Shifter Review/Thoughts
#21
I have a similar set-up. Just using the Seeker shift collar instead. Essentially the same deal. Can't imagine going back to stock.
#22
My shifter started to rattle once I put on a 267 gram NSX Alex Zanardi titanium shift knob while cruising in 4th or 5th. I didn't notice this with the OEM leather knob. I need to do some more testing and make sure it wasn't just a loose nob or because I have the center console off and I'm noticing it more than normal. I asked the S2000 guru's and was told this was a combination of:
- The metal shifter collar is causing to transfer the vibrations through the shifter, while the soft plastic one would dampen them.
- Short shifters have a tendency to rattle more than OEM ones.
- Installing a heavier shift knob can increase the chance of the shifter to rattle.
#23
I'm not a fan of the short shifter. I put one into my first AP1 and after about 6 or 7 track days, I pulled it and sold it.
I spent a lot of time with another in my AP2 only to come to the same decision but only after 4 track days with it.
I find that my countersunk shift knob allows me to shift into all forward gears easily even with just three fingertips even through the sift gate such as a down shift from 5 to 4 as entering the shift zone at the end of a long straight.
I would recommend trying one if at all possible before buying one.
#24
Just an updated review, since having installed it back in Feb 2017, shifter has broken in and the notchiness is definitely gone now. Had this paired with a Moddiction countersunk Anvil and this is just a badass buttery set up. Still one of my favorite mods.
#27
thanks for the reply! would you say the shifts are crisp, precise with less play in between gears?
#29
I just placed an order. I contacted Hiep at Renegade Motorsports and he said there are only 3 spots left so try and get in an order ASAP !
He said they are still several weeks out on them
Thanks for the info!!
#30
just placed my order. on instagram renegade stated theyre including brass shifter bushings
