Replacement of CAT
I am replacing my CAT. Is there enough slack in the sensor wires to simply twist them on removal and pre-twist for install?
I don't have a lift so I would like to minimize my time under the car. (I'm chicken)
Jim
Jim
Reach up above the transmission and unclip the sensor connector. The small tab is pulled up to slip the pair off of the bracket, then push the knurled tab to disconnect it. Takes 30 seconds. If the connectors won't release, push the plugs TOGETHER and push the tab until you hear a click.
mobile chicane
Jan 18, 2012 05:22 AM
