Sponsored by: CARiD
Replacment Air Filter
Old Mar 12, 2009 | 03:50 PM
s2000freak23's Avatar
Thumbs up Replacment Air Filter
Hey guys I usually drive without my stock air box cover with stock air filter. I dont want to buy a CAI yet. I wanted to just replace the filter, is there anything you recommend?
Old Mar 12, 2009 | 03:59 PM
s2k_636's Avatar
You can get some aftermarket replacement filter, but you may wanna put your airbox cover back since it actually helps not to suck hot air from your engine bay.
Old Mar 12, 2009 | 04:23 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
...and get a JR Filter.
Old Mar 12, 2009 | 05:20 PM
Artric's Avatar
JR?
Old Mar 12, 2009 | 05:41 PM
r6elmo's Avatar
why not go with a K&N replacement filter. someone in the for sale forum was selling a usd one for 15. new is about 50.
Old Mar 12, 2009 | 05:51 PM
gospeedgo1's Avatar
stay with stock, unless you want more "flow" at the cost of less filtration. how important is ~1-2 HP to you? put your cover back on unless you like sucking in hot air.
Old Mar 12, 2009 | 06:13 PM
RBS2K's Avatar
He most likely knows that taking the cover off causes heat soak, but likes the sound of it off.
Old Mar 12, 2009 | 07:49 PM
Thanks for the info about losing hp but I already know that but just like the sound. Its not like i am racing so its okay. Thanks alot though guys. Any other filter options, how about that AEM filter?
Old Mar 12, 2009 | 10:14 PM
ans2k's Avatar
^most filter, work about the same. they give about the same hp, but how it filter is all different. there are three types:foam, oil and dry. foam is the highest flow but least filtration. oil has more flow than dry/paper but less filtration. the paper most filtration but least flow. adding a filter will only give about 1~2 whp gain, which is in the range of dyno error. also, there has been no evidence that a least amount of flow has cause an engine failure, but it can lead to it. the only time i have seen an engine failure due to a filter is when i saw a monster turbo engine eat a foam filter and the engine when out. LOL FAILED!!!!
Old Mar 13, 2009 | 08:11 AM
Sobe_Death's Avatar
I plan on trying the Cosworth filter when my next change comes up.
http://www.gotuning.com/product_info.php?f...products_id=944
