robbins soft top install...easy
I have a 2005 s2000. Soft top was trashed. I ordered a Robbins stay fast from auto tops direct.
I am a auto tech so I might have a little more experience than most but I found the top to be a straight forward install. It took 5 hours to install. This was my first one but I could cut it down to 3-4 hours. Auto tops direct supplied a great product. The only problem I had was I didn't get rivets but I only needed two. One for each side to attach the cables to the frame. All the threads I read on this install made me nervous. In the end I think the shops over charge for this job. It calls for 9.5 hours. I could do 2 in 9.5 hours.
Anyone thinking of doing this job them selves. Just do it. Its not hard. Take pictures along the way for a reference
Did you end up using the directions found on here? The directions that come with the top are useless unless something has changed on their end.
Also, I just would like the say that it can be done with one person. I would not advise it, but it can be done. Having a second person or even third will make a tremendous difference.
Is it really that easy?
I've been on the fence about doing mine. There is a s2k member not far from me that installs them (many in the North Texas forum have used him) that I had considered using.
I would not mind saving some $$.......
