Rotora Rear Brake Kit
I got the front Rotora circuit brake kit installed in the front but the rear brake kit do not have the adapter for the Emergency brake line? How can the E line can be installed?
I might be understanding the situation wrong, but usually if you change the rear brakes to calipers, you loose the E-Brake. If you look at cars with the rear caliper upgrade, you'll see a separate e-brake "caliper."
I guess you can install the rear and never park on a slope, or park in gear...(joking of course - I wouldn't sacrifice my e-brake for a caliper setup that wont help the car that much)
edit: In addition, I hope Rotora has included some type of bias adjustment, otherwise your brakes will be worse than stock...
Note the smaller "caliper"
usafstud
Sep 13, 2018 09:26 AM
