Sponsored by: CARiD
Rpms
Old Aug 22, 2012 | 02:16 PM
mariod_7's Avatar
Default Rpms
ok so i bought my s2000 a couple weeks ago and i started seeing that i was wasting so much gas.. and i found out that my rpms are too high I'm going 80mph and I'm close to or on 5000 rpms... i want to know what i need to do to put it back to normal like how they came out of the dealer... please and thanks...
Old Aug 22, 2012 | 02:46 PM
mariod_7's Avatar
Old Aug 22, 2012 | 03:05 PM
El S2000's Avatar
I think my AP2 spins somewhere around 4000RPM
Anyways, it sounds like someone may have put aftermarket gears in the rear end with a higher ratio which would make it wind out faster but also be turning more RPM at 80. If your positive the MPH is correct I would look in that direction.
Old Aug 22, 2012 | 03:27 PM
mariod_7's Avatar
yea i think its crazy cuz i drive 100 miles and i have taken note and half my tank is gone.. so i know it kills gas and i don't want to drive it cuz i don't wanna over heat it, so whats your best guess for me to get it to be normal
Old Aug 22, 2012 | 05:53 PM
ans2k's Avatar
is it an ap1 or ap2? sounds like you have some 4.77 gears. good luck with that. what you need to do is sell/trade the diff for a stock one.
Old Aug 22, 2012 | 06:45 PM
Zoomie's Avatar
Near 5,000 at 80 and 100 is about halfway on the gas gauge sound about right... I would make some more careful measurements before you assume anything is wrong.
Hopefully it is all stock and you just need to get used to it. Congratulations on the new car!
Old Aug 22, 2012 | 07:06 PM
kap's Avatar
kap
4k rpm in 6th gear is 73mph for me. so it does seem like you have shorter gears in yours.
Old Aug 22, 2012 | 08:10 PM
Duyx817's Avatar
half way tank for me is about 150 miles
Old Aug 22, 2012 | 08:45 PM
HS2K.RLS's Avatar
Spammer
My stock 2007 AP2 turns 4200 at 128 Kph (79.53 mph) - sounds llike you need to check the final drive gears in the dif.
Old Aug 22, 2012 | 10:23 PM
s2cho's Avatar
theres a way you can find out. its by jacking up the car and turning the wheel. i think bilmin made a diy to find out... not sure tho....
