Sponsored by: CARiD
Running DRL at Full?
Old Dec 26, 2007 | 10:59 AM
al4t1gbundy's Avatar
Default Running DRL at Full?
Hello all,
I just got some PIAA Super Yellow H1 bulbs for my high beam. I was wondering if there is a way to run the DRL (day time running lights) at full high beam instead of half wattage so the yellow can stand out more instead of that dull bs.
Any help is apprecaited.
Thanks in advance.!
Old Dec 26, 2007 | 01:05 PM
wOlLeyLaBeL's Avatar
so you want to run the high beams all day? couldnt you just switch on the high beams then you would run it on full wattage...
Old Dec 26, 2007 | 01:45 PM
s2kologist's Avatar
the piaa's look alot better at 100%
Old Dec 26, 2007 | 04:10 PM
hipopkboy's Avatar
you can just turn the high beam on then? an click of a button
Old Dec 27, 2007 | 12:55 AM
AlX Boi's Avatar
You're going to have to buy something with a higher kelvin level to run it doing yellow @ half power. Is it really running @ half power or less?
Old Dec 27, 2007 | 04:33 AM
MitsukillinS2K's Avatar
thats not what hes saying. he wants to basically have his hi beams on all day so his PIAAs will use the power thats used for hi beam and not DRL
OP just flip on your hi beams
Old Dec 27, 2007 | 06:37 AM
nearwater4me's Avatar
I think the high beams wouldn't be constantly on unless you turn on the park lights.
Dan
Old Dec 27, 2007 | 09:30 AM
The high beams wont go on full power unless you have the low beams on.
Like I know can flip the switch and the high beams will go on, but it stays on only when the low beam is on. Otherwise its off. Can you guys clarify again how do I just "flip the switch?" I dont want to be running low beam in the daytime.
I gotta try that parking light thing though ..
But my point is 06-up have the nasty half wattage DRL (which is the high beam at half wattage) and I would rather have it yellow. The PIAA does not show up unless its full high beam.
Thanks again guys.
Old Dec 27, 2007 | 06:17 PM
AlX Boi's Avatar
Which is what I'm saying. I got 5500k for DRLs and it still shows up a little yellow because it's running @ half power. That just means I have to get a higher kelvin to have the DRLs look like the same color as the low beams.
Old Dec 28, 2007 | 10:27 AM
INTJ's Avatar
Ehhhh. The drl is the halogen highbeam, not the HID. There must be a relay activated to use the lower current, just trace the relay and re-route it to the higher current lead, or figure out how they lowered the current and bypass it with a full 12v.
But as far as the law goes, you are nuts to be driving around with the brights on all the time, they will blind oncoming traffic.
calvinnnnn
Oct 20, 2011 12:08 PM
FilthyAp2
Dec 6, 2008 08:14 AM
khiz
Aug 15, 2008 04:35 AM
enoyskt
Nov 5, 2003 09:30 PM
