Sponsored by: CARiD
S2000 Specific APR Performance GTC Wing
Old Nov 19, 2007 | 01:22 PM
  #21
asng's Avatar
thanks for the pix! does APR provide templates for drilling? i don't have the balls to drill my trunk blindly....
Old Nov 19, 2007 | 02:26 PM
  #22
Bryan@BerkTechnology.com's Avatar
Former Sponsor
One of the holes is actually the OEM wing hole. So it's already indented. Not sure if they give you a template for the second hole though.
Old Nov 21, 2007 | 07:15 AM
  #23
NoFriegue's Avatar
Bump for more info/pictures of this wing.
I tried emailing apr for info but so far no replies from them.
Old Nov 22, 2007 | 07:57 AM
  #24
Former Sponsor
What other questions do you have. I should be able to answer them. Or, if you are looking where to buy it, just put them up.
http://www.berktechnology.com/shop/product...ID=131&P_ID=468
Old Nov 23, 2007 | 05:51 AM
  #25
NoFriegue's Avatar
[QUOTE=Bryan@BerkTechnology.com,Nov 22 2007, 08:57 AM]What other questions do you have.
Old Nov 24, 2007 | 03:41 PM
  #26
ericg's Avatar
??? Info on the full height mounts?
Old Nov 26, 2007 | 10:58 AM
  #27
Former Sponsor
Full height mounts go in the same location as what you see in the pictures, just taller.
Here's another shot for the wing from the rear.
Old Nov 26, 2007 | 11:27 AM
  #28
FF2Skip's Avatar
For most tracks, the universal GTC-200 is fine. The problem comes from folks not mounting their wing far enough back on the trunklid. There shouldn't even be a finger's width of space between the vertical edge of the trunklid and the "pads." I have hit over 130mph with the AOA very high session after session- no creasing. That is not to say that there isn't any flexing occurring.
Conversely, the drawback to the wider mounts is increased drag caused by the stands. How measureable? I have no clue and promise you that I'm most likely not a consistent enough driver to ever tell the difference.
FWIW, I have the GTC-200 with the low-mount stands. They actually need to be about 5" higher.
Old Nov 26, 2007 | 11:30 AM
  #29
FF2Skip's Avatar
Originally Posted by TestaRossa,Nov 12 2007, 07:52 PM
btw, here's a pic of the bodyshop testfitting the stuff.
Too far forward. This is what I'm talking about. In order to pplace it rearward far enough, you will have to dremel existing opening in the trunklid.
Old Nov 26, 2007 | 11:32 AM
  #30
FF2Skip's Avatar
Hopefully these show just how far back you can mount the wing. The vertical edge increases the lids rigidity at that point greatly over the placement of TestaRossa's.
