Sponsored by: CARiD
Seeking opinions...
Old Mar 5, 2008 | 07:16 AM
sparky67's Avatar
Default Seeking opinions...
What do you all think??? To reduce body roll and improve handling.(mostly street and highways) of my 05 S2k, I am considering one of the following:
1. F/R Cusco sway bars, Cusco Front tower strut bar, and Eibach Prokit(1" drop)with OEM shocks.
2. KW V3 Coilcovers only and NO sway nor strut bars, OR
3. Sway and Strut bars AND KW V3's?
What will be an optimal cost/benefit setup? Is option #3 an OVERKILL for my driving need? How much of an improvement do you think? 20, 30, 40% or more? Furthermore, If I were to go #1 route, do I need to re-align after dropping 1" on a OEM wheels? Thanks fellas...
Old May 22, 2008 | 02:01 PM
Integra21's Avatar
KW V3's is your best bet. with stock tires you wont need sway bars and strut tower bars yield minimal gains in rigitity.
Old May 22, 2008 | 02:11 PM
tekstar's Avatar
For just street and highway you'd be better off going with just the eibach's. No need to have adjustable coilovers when you're not going to be adjusting them.
Any time you make a change to the suspension, you'll need an alignment.
Old May 22, 2008 | 02:34 PM
jirro22's Avatar
kw is ur best bet as stated by the other member above...
and u dont need to do alignment anytime you make adjustment on the kw coilover, unless you change the height..but if ur just changing the damping then theres no alignment needed...
good luck....
Old May 22, 2008 | 02:35 PM
shadwsndst's Avatar
pic up some V2's and save some coin, big improvement in feel over stock.
[QUOTE]KWV2 ftw.... I love mine.
Knoweyedea
May 7, 2012 11:21 AM
daveknipp
Apr 26, 2011 11:26 AM
SoCalAp2
Jun 24, 2009 01:19 PM
LivingLegend
Oct 14, 2004 01:52 PM
Ben-G
May 27, 2004 01:42 PM
