Sponsored by: CARiD
Shifter Bushings?
Old Apr 21, 2015 | 12:52 PM
S2Kmeister's Avatar
Default Shifter Bushings?
Hi Everyone,
I have an AP1 2002 Honda S2000 with 108k miles. Sometimes I feel like the shifting is pretty Notchy (but No grinding). I did some research and it looks like a pretty common thing for AP1's. My questions are:
-Why does the AP2 shift smoother (or even the new Si's like 2008 and above)?
-Would buying Shifter Bushings help make my car shift "smoother" and less Notchy?
Thank you all so much! No matter what, still love my AP1!! =]
Sam
Old Apr 21, 2015 | 01:04 PM
Moddiction's Avatar
Former Sponsor
This is a direct link shifter. No bushings. You may want to replace the pivot on the tip of the shifter and re-grease the shifter assembly though. That may help out.
Old Apr 21, 2015 | 01:33 PM
S2Kmeister's Avatar
Ah, thank you for the insight! So why does the AP2 feel like it shifts smoother? Even my friend's 2008 Civic Si seems to shift "smoother" and less notchy..
Old Apr 22, 2015 | 05:19 AM
jst2878's Avatar
Transmission bushings
Old Apr 22, 2015 | 12:08 PM
dc2-2-ap1's Avatar
You can't compare the shifter feel from a civic to an S2000. Those are 2 completely different types of transmissions. Like moddiction recommended, replace the plastic pivot ball, the plastic piece that holds the shifter in place, regrease everything and change your transmission fluid. Those should help to eliminate some of the notchy feeling.
Old Apr 22, 2015 | 03:25 PM
Car Analogy's Avatar
The ap2 uses 3 stage carbon fiber syncros, ap1 2 stage metalic syncros, hence even smoother shifts.
Your notchiness isn't from shifter itself, its from the clutch not fully disengaging. Replace fluid, using gravity bleed method to 2 birds one stone (fresh fluid, no air).
Then adjust your clutch rod for zero play.
You may want to regrease your shifter, and also the slave push rod, but not to reduce noticiness. Just smoother action.
Old Apr 22, 2015 | 04:40 PM
noodels's Avatar
Interesting will look into this ^^
quote: <Then adjust your clutch rod for zero play>
Noticed last drive i was putting pedal to the floor and seemed better..thought could be down to my slower gear changes and pausing in mid position.
will have a look in the daylight
Old Apr 22, 2015 | 05:06 PM
SOL1D's Avatar
Billman adjusted my clutch pedal to eliminate the first stage of loose play which you can get rid of but there's a second stage of play that's Suppose to be there from what he said, You should look into his post that discusses this in detail. Luckily Billman flew down to Cali for a week or so, so I got everything done when he was here that I didn't trust anyone else doing heh.
Edit: here's the the thread, scroll down to Billmans post describing the two different plays in the clutch rod https://www.s2ki.com/s2000/topic/289...now-very-high/
Old Apr 23, 2015 | 06:54 AM
S2Kmeister's Avatar
Thank you all for your input! I will definitely try this one of these days! Last question.. is it possible to use the ap2 carbon fiber syncros on the ap1??? (I apologize if that is a really stupid/noob question)...!! >_<
Old Apr 23, 2015 | 06:59 AM
Moddiction's Avatar
Former Sponsor
Easier to just buy an AP2 transmission and sell your AP1 transmission.
