Shine/Spoon diffuser mounting points?
I just recently installed the shine diffuser on my car, but I'm not too sure how its supposed to be mounted. I have it mounted in 6 locations: 2 on each end of the bumper, and 2 in the center between the exhaust.
Is there supposed to be a mounting point closer to the subframe? The end of the diffuser closest to the subframe drags once I start picking up some speed.
You have to stop driving the car with the diffuser on if you don't have the rear 2 points mounted. On my diffuser I had to make my own mounts. I bought water heater straps, bent them into a "Z" and used worm clamps to hold the mount against the rear subframe (round tube) and the other end of the strap bolted to the diffuser.
My mounts have held up fine for about a year now. High speeds low speeds etc.... The only problem I have is when I wash my car, my diffuser turns into a bird bath. I'm thinking about drilling drainage holes in the rear.
fluffy_monkey
Jul 25, 2016 04:52 AM
