Sponsored by: CARiD
Shine/Spoon diffuser mounting points?
Old Sep 1, 2010 | 12:26 PM
nitewing117's Avatar
Thumbs up Shine/Spoon diffuser mounting points?
I just recently installed the shine diffuser on my car, but I'm not too sure how its supposed to be mounted. I have it mounted in 6 locations: 2 on each end of the bumper, and 2 in the center between the exhaust.
Is there supposed to be a mounting point closer to the subframe? The end of the diffuser closest to the subframe drags once I start picking up some speed.
Old Sep 1, 2010 | 01:43 PM
wisdom's Avatar
You have to stop driving the car with the diffuser on if you don't have the rear 2 points mounted. On my diffuser I had to make my own mounts. I bought water heater straps, bent them into a "Z" and used worm clamps to hold the mount against the rear subframe (round tube) and the other end of the strap bolted to the diffuser.
Old Sep 1, 2010 | 01:46 PM
wisdom's Avatar
My mounts have held up fine for about a year now. High speeds low speeds etc.... The only problem I have is when I wash my car, my diffuser turns into a bird bath. I'm thinking about drilling drainage holes in the rear.
Old Sep 1, 2010 | 01:53 PM
GT Motoring's Avatar
Former Sponsor
shine does not provide an brackets. you will have to fab up your own
Old Sep 1, 2010 | 03:34 PM
s2sik's Avatar
i had all the same points you have installed, and then two more on the rear near the subframe that i put together out of some pieces from the local hardware.
Old Sep 1, 2010 | 04:21 PM
Sounds good. I havent been driving around with it at all, I just test drove my car around the block and heard it scraping. I was planning to fab up some mounts around that area anyways. Thanks.
fluffy_monkey
Jul 25, 2016 04:52 AM
ttang
Aug 14, 2009 08:57 AM
C-losAp1
Bay Area For Sale
Feb 18, 2009 12:37 PM
stockae92
Sep 26, 2002 04:21 AM
