Sponsored by: CARiD
Show your harness setup
Old Jul 9, 2009 | 04:34 PM
Olegator's Avatar
Default Show your harness setup
Hey guys!
Show off your harnesses' setups!
I know that there are a lot of different ways people install them, so let's figure out the correct way.
Thanks in advance!
Old Jul 9, 2009 | 04:45 PM
mikegarrison's Avatar
There's no mystery.
The shoulder straps go to the harness bar on the roll bar. The OEM seat belt mount point can be used on the outside. Another mount point is created on the inside by running a bolt through the tunnel and using a proper backing plate. The two sub straps go to the floor on either side of the beam that runs under the seat.
Old Jul 10, 2009 | 08:09 AM
Olegator's Avatar
cool, thanks.
What beam under the seat are you talking about?
Old Jul 10, 2009 | 08:22 AM
Originally Posted by Olegator,Jul 10 2009, 09:09 AM
cool, thanks.
Jack your car up and look. You'll see it.
Old Jul 10, 2009 | 08:55 AM
street_ruler's Avatar
also note that the shoulder straps need to the no more than +/-15 degrees off parallel to the deck and perpendicular to the shoulder. also consider if you are using a H type shoiulder strp, straight straps or Y type and an ASM cartridge (schroth only)
cat5cable
Jun 25, 2016 10:30 AM
youngjae
Jun 8, 2010 10:50 AM
Globe182jp
Mar 13, 2009 08:56 PM
kubos2k
Mar 20, 2006 03:30 PM
SpoonTypeR
Mar 16, 2005 05:36 PM
