where should i mount my 4 point harness?
You should not mount it. Use the OEM seatbelts unless you add a rollbar and 5th point to the belt.
See this thread for further clarification: http://forums.s2ki.com/forums/index.php?showtopic=143847
I disagree.........I have 4 point harnesses installed in my 02 without a rollbar and have had no problems with them. Would you be safer WITH a rollbar installed?....absolutely, but you're no less safe with harnesses than you are with a lapbelt. I find you are more secure and more "as one" with the vehicle with the harnesses than you are with the lapbelts which allow you slide around in the seat. Even in the extremely rare instance of a rollover, I can't imagine a lapbelt would offer you any more safety than the harnesses would. I see much more advantages with harnesses than without regardless of whether you have a rollbar installed or not. I'll stick with what I have................................just my .02
You are 100% wrong oneaudiopro.
In the event of a head on crash your body is going to want to go forward, the only way it can do that is by sliding down under the harness, your harness wont budge and will thus travel up into your gut breaking ribs and causing internal bleeding.
If you have your harness mounted anywhere below shoulder level then your also going to have the joy of experiencing spinal compression.
You have fun with that, and next time, don't spread your misinformation that could potentially be lethal.
Administrator
Please don't give people advice that can potentially impact their life in a negative fashion, especially something such as this that is a well known
Harnesses should be 5 point or more. They should only be used with a rollbar and appropriate mounting arrangement (typically a harness bar) and installed according to standard safety practices. To do otherwise makes them less safe than the factory 3-point belts.
Clueless are you.
Hey Ludedude...are you going to the Cal Speedway Speed Ventures event in May?
