Sponsored by: CARiD
Skunk2 Megapower w/ Berk High-Flow Cat, need help!
Old May 7, 2011 | 03:38 PM
Vivid_27's Avatar
Default Skunk2 Megapower w/ Berk High-Flow Cat, need help!
So I'm running a Skunk2 Megapower on my S2K right now and want to buy a Berk High-Flow Cat. It comes in 2 sizes, a 63.5 mm or a 70 mm. I'm pretty sure I should go with the 70 mm but I'm not exactly sure. I know the piping on the Megapower is 70 mm. Does that mean the two have to match? What size do I need?! Thanks.
Old May 7, 2011 | 08:31 PM
Torque Obsessed's Avatar
63.5mm is similar to the OEM cat, so it'll improve flow just because it's more porous. 70mm is bigger and matches your cat-back, so it'll improve flow even more than the 63.5mm. I think somebody made a thread showing dyno comparisons of the cats.
But... Be prepared for some serious loudness. I had that combo before and it was like having noise cannons behind the car. HFC makes the exhaust deeper and much louder.
Old May 8, 2011 | 05:06 AM
Importedpower's Avatar
what year s2000 do you have? I have an 02, and i used to run a full 70mm exhaust, berk header, and berk HFC, with skunk2 megapower duals. I ended up trading the HFC for a test pipe because the HFC makes interior reverberation absolutely awful inside the car. The test pipe made it a little louder, but it goes straight out the back of the car. If you have a year that can run a TP without setting off the CEL, i would get the test pipe...
Old May 8, 2011 | 06:55 AM
suzuka-blue-s2k's Avatar
Always match youre HFC or test pipe size to your exhaust for the best results. I also agree with them above.
Old May 8, 2011 | 08:23 AM
TruBluS2k's Avatar
is the interior reverberation with a berk HFC that bad? I guess i might as well get a test pipe then. I just dont want my exhaust to be dumb loud i have a mugen header and exhaust
Old May 8, 2011 | 09:37 AM
HFC just makes the exhaust deeper and meaner, and magnifies the volume of whatever you already have. 10% increase to OEM is nothing. 10% increase to skunk2 is noticeable.
Old May 8, 2011 | 04:34 PM
alricl's Avatar
I would go HFC sounds better and not as loud or smelly as a testpipe from my experiences running both on my Ap1
Old May 8, 2011 | 04:52 PM
2000AP1's Avatar
How about 70mm berk HFC with 70mm Invidia Q300 dual? Will it kill my passenger (my fiance) when I am cruising (say below 3000-3500 rpm)? I still want to be able to listen to my music when alone and/or talk to my fiance when I am driving (either with top down or top up).
Any feedbacks would be appreciated
ATNCHN
Apr 26, 2017 10:17 AM
juxty_s2k
Jan 4, 2016 01:49 PM
EireannS2k
Aug 12, 2009 02:09 AM
scutrCR
Feb 20, 2009 02:50 PM
krazyguy316
May 18, 2006 07:38 PM
