Spoon Engine Mounts - Liquid Filled like OEM?
#91
Site Moderator
Lol a video of what exactly? I can't really think of a way to video the difference these mounts would make. Other mods would make a more noticeable difference in a video.
#92
Yeah if I were to take a video of my car with the Ballade mounts vs OEM you wouldn't see any difference.
#93
#94
It's difficult to capture in audio or video, but I sure feel it in my butt! The Spoon Mounts have introduced a harmonic vibration into the car that can be fairly annoying when idling or cruising around town. Fortunately, in full VTEC mode with what's left of my hair blowing back, I don't even notice it.
I'll have to give a review on my mismatch setup when I finally get it installed. Vibratechnics engine mounts and Hardrace trans mounts. I was under the impression that Hardrace didn't sell the mounts separately, but Heeltoe has just the tranny blocks for sale.
#95
Also, do you consider them broken in? Or still fresh when you feel the rumbling at idle?
#96
Imo if you have a stiffer rubber you're always going to get increased vibration. I wouldn't worry about it much. When I went from Stock to full poly and then from full poly to the SPT (stiffer rubber) mounts on my STi I basically had almost the same stiffness as the poly but NOWHERE near as much NVH. It's unavoidable, and in some instances you'll notice slightly more vibration and then you get used to it; you won't with poly....and I consider myself pretty tolerant of a little added noise and vibration.
Poly sucks.....after a while things start to squeak and fall apart; they need to be greased regularly. That's why you see a lot of poly bushings with zerk fittings.....Rubber is much more durable in that regard. Might not be as rigid, but serviceability (or lack of a need to) is a huge thing for me with rubber over poly bushings. They last much longer.
#97
I'm sure he's got both as the Spoon comes as a set (engine + trans). Afaik the Vibratechnics mounts are the only ones that are sold as engine mounts (they don't make a trans mount). I had purchased new OEM trans mounts until I just discovered today that you can purchase the hardrace trans mounts separately, so I got my order in. I also saw that Hardrace makes a full suspension bushing kit for our cars, and contacted Heeltoe about being able to get it; they can. Part number is Q0079; selling my Prothanes and running those instead.
Will probably get an ETD because I'm so intrigued by it. Once the blower goes under the hood it may be impossible to run the ETD I want (traditional VTEC style mount) and at that point it may be best for me to get the Spoon rubber kit.
#99
I'd rather stay away from poly period. Spoon for me if the time comes (or Vibratechnics as in your case which you already have). When fitting my J's 70RS my friend and I looked closely at my mounts and immediately he compared them to his old ones which were torn by the time he replaced them and he said "your mounts are still good dude". Mounts money can be used elsewhere in my build then
Also, since we're here....check out these nice little numbers I picked up just to add a little spice
#100
Wow those look very impressive! Looks like a good quality kit from Vibratechnics. Looking forward to your impressions asap. 5mm clearance ought to help you with the strut bar.
Shiny new keys eh? Nice
